DAQmxRegisterEveryNSamplesEvent how to pass the data to the main application
I want to write a GUI Application (C++, Qt) with using this function. I used the sample code which comes with the NI installation:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Events\Every N Samples
But I'm not able to bring the data to my main application, as can't access any functions or variables on my application, as well as qDebug() calls also don't work.
Here the sample code I use to test:
#include "mainwindow.h"
#include "ui_mainwindow.h"
#include <stdio.h>
#include <nidaqmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData);
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
MainWindow::MainWindow(QWidget *parent)
: QMainWindow(parent)
, ui(new Ui::MainWindow)
ui->setupUi(this);
initNI();
MainWindow::~MainWindow()
delete ui;
void MainWindow::initNI()
int32 error=0;
TaskHandle taskHandle=0;
char errBuff[2048]={'\0'};
qDebug() << "Hallo";
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIThrmcplChan(taskHandle,"cDAQ1Mod2/ai0","",0.0,100.0,DAQmx_Val_DegC,DAQmx_Val_K_Type_TC,DAQmx_Val_BuiltIn,25.0,""));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"cDAQ1Mod1/ai5","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,100,0,EveryNCallback,NULL));
DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(taskHandle));
//qDebug() << DAQmxStartTask(taskHandle);
qDebug() << "Acquiring samples continuously. Press Enter to interrupt\nTaskhandle: " << taskHandle << "\n";
getchar();
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
qDebug() << QString("Fehler: %1").arg(errBuff);
if( taskHandle!=0 ) {
// DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
qDebug() << QString("DAQmx Error: %1\n").arg(errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return;
int32 error=0;
static int totalRead=0;
int32 read=0;
float64 data[2000];
uInt32 i;
qDebug() << "Callback";
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(taskHandle,-1,10.0,DAQmx_Val_GroupByScanNumber,data,2000,&read,NULL));
if( read>0 ) {
for (i = 0 ; i < 2*read ; i++ ) {
printf("%.5f\n", data[i]);
qDebug() << QString("Acquired %1 samples. Total %2\r").arg(read).arg(totalRead+=read);
//printf("Acquired %d samples. Total %d\r",read,totalRead+=read);
fflush(stdout);
Hallo(); // this function cannot be called
Error:
if( DAQmxFailed(error) ) {
// DAQmx Stop Code
qDebug() << QString("DAQmx Error: %s\n").arg(errBuff);
return 0;
int32 error=0;
// Check to see if an error stopped the task.
DAQmxErrChk (status);
Error:
printf("DAQmx Error: %s\n",errBuff);
return 0;
void MainWindow::Hallo()
qDebug() << "Hallo Callback";
Message 1 of 1
(835 Views)
