DAQmxResetDevice Error -223747, PCI-6220, Version 8.0.1f0
At most installations the application (Matlab based, compiled application, measuring with PCI-6220) works fine.
At only one installation I sometimes get error -223747 (internal software error) when calling the ResetDevice by the VisualC functions. This occurs rarely, typcally after 3 to 6 days. This vanishes after restart of the PC, but occurs again after a couple of days.
Are there any known issues, that might give me a hint (timing problem, A/D device not operating properly,...), where to look?
Does a newer driver version (actually used 8.0.1f0) help because of a known bug fix (I did not do it because it is a PC not in my office, where the remote connection is not so fast)?
Kind regards
Ralph
(3,104 Views)
Newer version certainly helps in such error scenarios. I'll recommend you to download and install latest available drivers.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,102 Views)
