DAQmxResetDevice returns -88705 - PCI6111 with DAQmx 9.0.3
I am trying to upgrading from Traditional DAQ 7.4.4 to DAQmx 9.0.3 on PCI6111 control by C++.
I use DAQmxResetDevice("Dev1") for resetting PCI6111, but it returned -88705.
I confirmed MAX 4.8 and recognized MAX can access to PCI6111. That looks strange.
I searched past Q&As and found the following thread.
http://forums.ni.com/t5/Multifunction-DAQ/Error-88705-with-USB-8261-at-system-boot-Must-cycle-power-...
But, it was a problem of version 8.7.1 and the answer was "It was fixed on 9.0.2.
As above, I encountered this error with 9.0.3.
Does anyone know what case can cause this unexpected return?
Neppie
(3,323 Views)
Hi Neppie,
My name is Yusuke Minami, Applications Engineer, National Instruments Japan.
Is your PCI-6111 board recognized as NI PCI-6111 "Dev1"  in MAX under Devices and Interface? Does the same error occur when you right-click NI PCI-6111 "Dev1" and choose Reset Device?
If so, would you try switching PCI slots to troubleshoot?
If the error does not go away with other PCI slots, your board might be out of order. Please contact your nearest office of National Instruments.
Yusuke Minami
Applications Engineer, NI Japan
日本ナショナルインスツルメンツ株式会社 技術部 巳波裕介
Yusuke Minami, Applications Engineering, National Instruments Japan
技術サポートウェブページ: http://www.ni.com/support/ja
お問い合わせフリーダイヤル: 0120-527196
(3,307 Views)
