DAQmxWriteAnalogF64 clean up dynamically allocated data
I want to use a dynamically allocated memory in a call to DAQmxWriteAnalogF64.
float64 *data = malloc( dataPoints );
The call works as expected but I am not able to free the memory without an error. Even after the task is stopped and cleared I cannot clean up the allocated memory.
DAQmxStopTaks( taskHandle );
DAQmxClearTask( taskHandle );
if( data )
free(data);  // causes error
(3,386 Views)
Accepted by topic author Chris_c++
Hi Chris_c++,
Can you show your code for filling in the data buffer and passing it to DAQmxWriteAnalogF64? If you write past the end of the buffer, the C runtime library's memory allocator may crash or terminate the application with a runtime error when you call free(). My guess is that you really need to allocate dataPoints * sizeof(float64) bytes, not dataPoints bytes.
Brad
Brad Keryan
NI R&D
(3,377 Views)
Hi Brad,
My mistake. You are correct.
Thank you for the response!
(3,372 Views)
