DAQmxWriteDigitalLines slow execution time (1-2ms, buffered write)
Hi!
I am writing a program that runs an X-Series DAQ as a master SPI device, using the DAQmx ANSI C function library.
As described on the page Serial Protocol Communication Reference Design for Digital Waveform Devices (http://www.ni.com/example/31200/en/), for every SPI communication I need to write digital samples to an output buffer using the command DAQmxWriteDigitalLines.  I'm using the daqmx>>correlated DIO section of this guide as I'm the output of a counter as the clock for digital input/output timing.
Unfortunately, execution of this function generally takes 1-2ms.  Very occasionally (~5-10% of iterations), this function takes only 100-200 microseconds to execute.  The time taken to execute does not depend on the number of samples that I'm writing to the buffer.
My questions are 1) Is this 1-2ms execution time typical and 2) is there any way to speed this up, so that it consistently takes only ~100-200 microseconds?  Currently this function is the only part of the SPI routine that takes order of ms (and not 10s to 100s of microseconds) to execute.
I have timed the DAQmxWriteDigitalLines command in example WriteDigChan-ExtClk.c as well - it also takes approximately 2ms to execute.
Equipment specs:
PXIe chassis, with PXIe-8370
Computer: Intel Core2 Duo CPU, 2.93GHz, 2GB RAM, Windows 7
Thanks in advance!
(2,802 Views)
Accepted by topic author mwolfe
Hi again!
I believe I have solved the problem!
I queried the write wait mode using DAQmxGetWriteWaitMode, and found that I was checking for available buffer space once every 1 ms (this mode is DAQmx_Val_Sleep, sleep time found using DAQmxGetWriteSleepTime).  Using  DAQmxSetWriteSleepTime, I reduced this sleep time to 0.1ms. This works!  I suppose I could also play around with the other write wait modes (see http://zone.ni.com/reference/en-XX/help/370471AB-01/mxcprop/attr22b1/).
(2,731 Views)
