DAQmxbase Acquire N samples Around Pulse
I've been struggling with what should be ostensibly a simple problem.  First off, I am working with DaqMXBase (3.7) on a Macintosh-- I realize this limits my options for potential solutions, however my goal is to construct a cross-platform solution for field research.
I am building a signal recorder for electric fish-- these fishes produce intermittent voltage pulses over time (~10ms or so, about the length of an action potential for those neuro nerds out there!).  I would like to record the waveform of a single pulse, which varies by species.  I have built most of the VI as a state machine in LabView, but have been struggling with how to implement a very simple software trigger to capture these waveforms.
I've set up aqcuisition succesfully of N points ('live data mode'), but what I'd like to do is set a level threshold in this window (at the amplitude of the electric fish signal), and capture a window of n/2 points on either side of the signal where it crosses this threshold.  Seems simple enough, perhaps one of the wise members of the boards can help?
Best,
Jason Gallant
(3,908 Views)
This sounds like you might want to look into Pretriggered Acquisition. Here is a link with some more information on Data Acquisition Triggering: http://www.ni.com/white-paper/4329/en
Section 4B might be useful for you. This is for DAQmx however, so support on this might be limited in DAQmx Base.
(3,881 Views)
