DAQpad-6016 Driver installation error
Hi.
I have DAQPad-6016 and NI-DAQmx V7.4 installed on my computer.
But the DAQPad USB driver not work, It's shows error in device manager: Windows cannot initialize the device driver for this hardware. (Code 37)
Driver version: nipalusb.sys (1.9.0f0)
OS : windows XP pro + SP2
(3,473 Views)
Hi Vitaly,
I am looking into this issue.  I was wondering if the device worked correctly at some point, and just recently showed this behavior or has it not worked since you started trying to use it.  I would recommend updating to the latest DAQmx driver supported by your programming enviroment.  NI-DAQmx 8.5 was just released so if you are using LabVIEW 7.1 or later I would recommend installing that.  It seems likely a driver error of some type is causing the problem.  It is unusual that the error come from the Device manager side, so you might consider uninstalling NI DAQmx, and Measurement and Automation explorer before running the new installer.  You can do that from Add Remove programs in control panel and going to NI Software.  Let me know if this resolves your issue and I will stay on top of any new updates you have.
Have a great day,
Michael D
Applications Engineering
(3,455 Views)
Thanks Michael
I found the problem Smiley Happy Simply after installation on "Clean Computer" need make RESET after install. The setup program don't tell to do that Smiley Wink
After reset all start to wort with out problem.Smiley Very Happy
(3,413 Views)
