DAQread stops without errors
I control a measurement setup with a CompaqDAQ and read voltage values with a DAQ-9205. The DAQ-9205 is read with a finit sample number (30) and a rate of 1k configured in the task. What happens is, that the programm stops suddenly (maybe about an hour, but not allways the same time) in front of the DAQmx-read-VI (LabView2010 function). You can see running the error cluster in the read-VI but not coming out, the program just stands still without an error. Has anyone an idea what happends here?
PS: I fixed the problem by using an express-VI. There the program does not stop. But for higher performance I what to split the DAQ-Init and the DAQ-read.
(3,278 Views)
Hi
Could you please upload your VI so that I get an impression what might be wrong?
You should always try to use all of the VI's shown in the example VI to get highest performance results.
Regards
Christian
(3,260 Views)
Thanks for the replay,
i have added my LLB
Regards, Johannes
(3,257 Views)
