DAq 6368 to generate custom bit pattern
I am trying to create bit pattern  of 4 bit 1010 using NI -DAQ card 6368.
My bit should be sample at 2Mhz. I see that NI-DAQ card allows sample clock of 10Mhz. SO I think, its possible. I created VI to create custom bit pattern but some how I am not able to see waveform on my scope.
My VI does not give me error so I am not sure what I am doing wrong? any help will be appreciated.
thanks
(4,079 Views)
Hello Analog_lab,
I would recommend taking a look at our LabVIEW shipping examples on setting up a Digital Output Task.  You can find them by navigating to Help>>Find Examples...>>Hardware Input and Output >>DAQmx>>Digital - Finite Output.vi.
Two things I notice is that the DO task line grouping is set to One Channel for Each Line whereas the DAQmx Write is for 1 Channel & N Samples.  It looks like with this line grouping, you would be looking at NChan NSamples since you are using lines 4 to 7.  I think that the Digital Output example will shed some light on what I mean.
I hope this helps!
Nadine H.
(4,050 Views)
