DDK Examples Not Working With DAQCard 6036e
I am working with a PCMIA DAQCard 6036E on a WinCE.net  device (Inhand Elf3) using Embedded Visual C++ 4.0 to compile and run the AIEX1.cpp example. This example simply acquires one sample from channel 0.
The issue I'm having is that no matter what voltage I apply to the channel 0 inputs I receive the same input value (31745). I have similar issues with the other examples (input values never change and sampling takes a very long time, ~1 sec per sample).
As far as I can tell I've done things correctly. I downloaded the DDK and ESeries chip objects, successfully compiled and installed the driver, etc...
Is there any sort of diagnostics or tests that I can do to check if I'm actually able to do to ensure the board can be accessed and is working? What other steps should I take in order to find the problem?
edit: This was supposed to be posted in the DDK forums.
Message Edited by Dave Humphrey on 05-24-2006 03:02 PM
Dave Humphrey
humphrey@ppic.com
www.ppic.com
Message 1 of 1
(2,887 Views)
