DIO96-Board (PXI-6508) spikes after initializing
The ports of the PXI-6508 are configured as pulled up inputs at default.
Therefore we have designed our connected test-hardware to be in the reset
state when beeing operated with the high-level signals after power-up.
The problem is, that after configuring the ports as output, they have a low
state ! Even if I set the ports to high after configuring them, I can't prevent
them to deliver a short spike which stimulates our hardware.
Is it possible to set the default output-value that should be driven before
configuring the ports as output ?
Thank you,
Manfred Schininger
Message 1 of 1
(2,663 Views)
