DMA access in 6259 using labview
Hi , I am using a usb 6259 DAQ . Have the following questions .
1) How can the DMA access done in this device . Is there a feature which configure the dma in this harware or by default it is used by the channels.
2) While sampling a analog signal or a digital signal  if the sampling source is not specified then which source is taken as default source.
3) Can digital and analog signal be sampled simultaneously ? As mentioned in its specification , only simultaneous sampling of analog signals cant be dont . Then how about sampling of analog and digital signals sampling simultaneously.
4) Where are FIFO situated in the Hardware ? Is it in DMA or external to it? Can FIFO be externally configured?
5) Can a digital output from port 0 routed to PFI 0 and read back into labview ?  Because i want to use this digital signal as a trigger source .
regards
AVINASH
Message 1 of 1
(2,842 Views)
