Daq Assistant acquires data in chunks
I am trying to write a code that will read and record voltage, temperature and strain on a cdaq 9174 using ni 9221 and ni 9173 cards.  The problem is that when the daq assistant is set to N samples it outputs chunks of data in the graphs.  I would like it to be a continuous stream so I can see what is actually happening.  I have tried changing it to continuous but it either gets an error or takes around 16000 data points in about 10 secs which is way more than I would prefer.  The code I am using is borrowed from someone else and when setting it up exactly the same it works on that computer, but not mine.  Does anyone have any suggestions on how to solve this problem.  I have attached the code as well as the sub vis that is uses.
(2,741 Views)
Duplicate
Peter D
(2,739 Views)
