DaqMX 19.0 runtime ?
The Full DaqMX 19.0 SDK is available
http://www.ni.com/fr-fr/support/downloads/drivers/download.ni-daqmx.html#301173
But why is the "run time only" not available for download ?
Message 1 of 25
(7,966 Views)
He's on the way.
you can still work with runtime 18
Message 2 of 25
(7,933 Views)
Ok, I in that case I just find it surprising that SDK and client run time are not released together.
By curiosity, can you explain why ?
Message 3 of 25
(7,931 Views)
Sorry I'm not from the R&D so I don't have more information.
Message 4 of 25
(7,928 Views)
DAQmx 19.1 is out, but still no download options for the runtime or runtime with config support options. Are these still on the way?
Also is it possible to install older DAQmx runtimes (not full installs) with NIPM? I can't seem to find an option anywhere.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 5 of 25
(7,807 Views)
Same question, the runtime is really needed to deploy to client machines !
Message 6 of 25
(7,805 Views)
It seems the solution is to select the full DAQmx driver in NIPM, begin installing it, then deselect everything from the additional package list to install only the DAQmx runtime (how intuitive). It still wants to install the NI-DAQmx package (plus a whole heap of others) in addition to NI-DAQmx Runtime, so I'm not convinced it's the runtime only.
The offline runtime installer solution is basically 'build your own'.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159txSAA&l=en-US
Message 7 of 25
(7,788 Views)
This is still not acceptable since client machines might not be connected to the network.
Message 8 of 25
(7,777 Views)
And of course, copying a ~3.5GB offline installer on each client machine is kind of less handy than the ~250MB run-time setup.
Message 9 of 25
(7,773 Views)
RunTime 19.5 is out, still no run-time deployment since 19.0
Message 10 of 25
(7,514 Views)
