Data Aquisition using ADVANTECH DAQ Card in LabVIEW
I am using ADVANTECH DAQ card for data aquisition in LabVIEW. But the problem is I am able to get the signal in LabVIEW, which is visible only in waveform chart. I want to get in Waveform graph. How can I? It is actually a sinusoidal signal Plz Help .
(4,330 Views)
hi.
u must put it in a while loop. or use a collect signal in your block diagram
(3,308 Views)
You've posted to the wrong board. This is for NI DAQ.
You also have not provided nearly enough information. If you are acquiring one point at a time, s chart of appropriate. A graph is used when you acquire multiple points at a time. Each depends on how you've actually configured the acquisition. I've never used your hardware so I don't know what is or is not possible with it.
(3,304 Views)
