Data acquisitio: Reset by press save
Hello everybody,
I'm about to acquire Data with DAQmx.As the attached Vi shows. the data muss be acquired continuously in the loop since save pressed. once save pressed the data will be acquired and saved til the stop-condtion is verified.
Setting-parameter for the Acquisition are sample frequency: 12500 Hz, number of Sample: 2048, Timing for the save 2 min, meaning after 732 Iteration. my question is: how could i set the loop condition so that by pressing save the iteration reset and start to count from 1 to 732 and store data over that elapsed time.
 I thank you so much for the suggestions
(4,514 Views)
