Data acquisition stops during single pulse output (long pulse = 10 hours) [NI USB 6210]
Hello, guys. I am facing some problems when trying to create a VI for data acquisition and controlling a relay.
I want to measure the voltage of a battery during charge and discharge. During the discharge, when the voltage falls to a specific value, a single pulse from a counter turns on a relay that inverts the polarization and starts the charge. This pulse lasts all the charge. When the pulse ends, a new discharge begins. The problem is that while the pulse is being applied, the measurement does not work, but when the discharge starts again, data acquisition works fine. I have tried continuous samples, N samples and so on, but nothing worked. I am a beginner on LabView so any advice will be great. Block diagram and VI files are attached.
(2,573 Views)
Instead of a counter, use a standard digital output.  I am pretty sure the counter task must finish before the loop will iterate.  If going the DIO route, use the Elasped Time function to decide the state of you DIO.
(2,543 Views)
