Data acquisition
Hi there,
Im using NI USB6008 for data acquisition from 6 devices sampled at 1000Hz. Every time I started the process, after like 20 - 30 seconds, this error message will  pop out 'No transfer in progress because the transfer was aborted by the client and the operation could not be completed as specified'. And after I reset the device (NI USB6008) from the NIMAX window, it will run for roughly the same period and stop again  with the error message been displayed. could someone help.
Tjuy
(3,221 Views)
Do you have any code you could share?  That might help point to something.
The other thought I am having is to make sure Windows isn't turning off the USB hub on you.  You can go into the device manager and turn off the power saving "feature".
(3,205 Views)
