Data conversion NI USB 6008
Good day, I am working with LabVIEW 2012 and THE  DAQ NI USB 6008, in which I am reading the values in a temperature and humidity sensor, which I'm plotting, but I need to send them to another PC running LabVIEW 2012, the problem is as transform these data from the USB (Dynamic data) to send so right through waveform for TCP / IP, thanks.
Message 1 of 1
(3,082 Views)
