Data logging using USB 6008
Im currently using the USB 6008 to log several analog inputs, i have a main loop in which the samples are being read, this all works fine and at a speed of approx. 150 S/s now when try to log the read data into a measurement file, the speed drops dramatically to 15 S/s. Is there a way to log the data inside the main loop without this loss of speed. i dont want to log the data in the closing sequence because if the program fails it logs nothing.
Thanks in advance,
H. Anbeek
(3,085 Views)
Is it possible for you to post your code so I can take a look at it?
Which version of DAQmx Base are you using and what version is your development software?
RikP
Applications Engineering
Rik Prins, CLA, CLED
Software Development Engineer
(3,075 Views)
