Data off whirling arm
Has anyone taken sensor data off a whirling object? We have a test rig which
is a stationary whirling arm (similar to a helocopter rotor) to which we
mount specimens and expose to rain. I would like to put sensors (piezo film,
TC, etc.) on the tip and take the data off. So far my only idea is an infrared
data link in the blade's center.
Thanks...
Chuck Blair
Univ. of Dayton contractor
AFRL/MLSA Rain Erosion Test Technician
(3,269 Views)
Hi Chuck,
The traditional way to do this is with an inductive coupling or
slip rings. There are a number products for the industrial
market available. Do a search on non-contact signal
transfer or short range telemetry.
Here is a link to a manufacturers paper on non-contact
transmission:
http://www.manufacturing.net/magazine/dn/channels/tecpapr/baluff.htm
Optim Electronics Microdac looks like it will meet your
requirements.
http://www.optimelectronics.com/product_files/microdac.html
These are just suggestions. I don't have any actual experience
in this area or with these specific products.
Reed.
Chuck wrote in message <39eb121e@newsgroups.ni.com>...
which
film,
infrared
>Thanks...
>Chuck Blair
(3,269 Views)
Don't forget that whatever method you choose, you must somehow get power to
any sensors.
Thus, you must have at least a pair of power slip rings, or you must have a
battery on board if you go the telemetry route.
By the way, even if you have dozens of sensors, you can probably get by with
one multiplexed telemetry channel.
Scott
"Reed Blake" wrote in message
news:39eb2cc1@newsgroups.ni.com...
> Hi Chuck,
> transmission:
> requirements.
> Regards,
> Reed.
> which
> film,
> infrared
> >Thanks...
> >Chuck Blair
(3,269 Views)
Make sure that your signals aren't too weak. When using slip-rings it can
result in unusable data...
Ronald
Scott Seidman schreef in berichtnieuws
39eb4627@newsgroups.ni.com...
to
> any sensors.
a
with
> Scott
> > Hi Chuck,
> > slip rings. There
> > transmission:
> > requirements.
> > Regards,
> > Reed.
> > which
we
> > film,
> > infrared
> > >dat
> > >Thanks...
> > >Chuck Blair
(3,269 Views)
