Data qcquisition though DOS
I am working on an instrumentation proyect with
a
recently purchesaed NI PCI 6013 data acquisition card (driver software:
NI-DAQ 6.9.3). I need to read a single signal (NRSE type) with an old
version of Borland C++ through DOS, which means I cant use the functions
included in the nidaq libraries.
Can I read the signal with the "importb()" function? Which is the name of
the port I should use?
Could you provide me example codes?
I would really appreciate any kind of help.
Cristian Baehr
(2,677 Views)
not possible with w2k and xp, ports are blocked
w98 may work
(2,677 Views)
