Determining DAQ for Galvo Control
Hi Samik,
Like many others, I have had the same query about which DAQ to pair with the galvanometers and how to make the connection.
I would appreciate your advice.
J.
Message 11 of 14
(532 Views)
Hello QDSpec,
I am new at Labview and I have to generate a code to control my X and Y galvos to do and scna and then acquire an image, sinchronized with the galvos. I am using your .vi to generate the output to my X and Y galvos, but now I don't know how to do it to sinchronize an Input to acquire an image. Could you help me?
I am using a DAQ USB-6001 to do the control, and Ill use a Photoreceptor for the image.
Thank you a lot
Carla
Message 12 of 14
(439 Views)
I have same query, did you find the answer ?
Message 13 of 14
(355 Views)
May I ask how quick was your raster scan and how could you connect the wires between the servo and the DAQ card, please? By the recommendation it read that we need 3 wires, +, - and ground. How did you connect to it?
Message 14 of 14
(302 Views)
