10-03-2007 11:18 AM
10-04-2007 04:12 PM - edited 10-04-2007 04:12 PM
Hi Wes,
I do not think the location of your PC is the root cause of the problem, but you may want to ensure that all your connections are good. I would first suggest trying the solutions in the article, KB 45HGAIJQ: DAQmx Error Code -89130: Device is not Available for Routing.
Keep me posted on your progressMessage Edited by Hani R on 10-04-2007 04:13 PM
10-05-2007 09:14 AM
If there is a bad connection, where would it be? Is it saying that the connector block is unhooked? or is it somehwere else in the system? The odd thing is that it works sometimes and always works in the original location or if I turn it on in my office.
I never have the problem when the computer is in the old location, and the only differences in the setup is where the power is connected to. This leads me to believe there is either some kind of electrical problem or outside interefence. Also, it will not let me attempt to reset in MAX, unless I am looking in the wrong place.
Wes
10-08-2007 12:04 PM - edited 10-08-2007 12:04 PM
Message Edited by jaced on 10-08-2007 12:06 PM
10-08-2007 04:02 PM
I was able to get through the problem by setting the device loader to automatic. I'm not sure why it wasn't setting to this upon startup (it does most of the time).
I'll let you know if I encounter the problem again.
Wes
