Device supported DAQmx function calls
Hello World,
I have a DAQ device and I would like to know which DAQmx (ANSI C) functions are supported
...and...
I am looking for a DAQ device supporting specific DAQmx (ANSI C) functions
Any idea/suggestion where can I find an overview of which device supports which DAQmx function calls?
Bjorn
(3,279 Views)
I'm not sure such a list exists.....however, you could create a simulated device and program as if the hardware is present.  You will get appropriate errors if the hardware does not support a particular function.  See:  What are NI-DAQmx Simulated Devices and How Do I Use Them?
-Alan A.
(3,257 Views)
Dear Alan,
Thanks for your idea of using the "device simulator" to check specific DAQmx (ANSI C) functions on different devices. It works very well (and I did not know this feature)!
Thanks!
...sorry for the late response (due to holidays)
(3,220 Views)
