Differential Analog Ouput Card
Hi
Can we have access to a Differential Analog Out card with NI....?
We only find single-ended Analog Card type.
Do we have a solution for this kind of signal ?
(5,611 Views)
Hi Boutch19,
Unfortunately we do not offer a differential analog output card.  We do have the work-around of using two single-ended outputs, which you mentioned.  The best options for this are the following:
PXI-6733
https://www.ni.com/en-us/shop/model/pxi-6733.html
Or the PXI-6723
https://www.ni.com/en-us/shop/model/pxi-6723.html
On either of those pages  you can click on the datasheet to get a family overview of the Multifunction DAQ AO boards
http://www.ni.com/pdf/products/us/4daqsc362-365_372-373_368.pdf
Sorry we don't have exactly what you're looking for!  I hope this information is helpful.
Julian R.
(5,581 Views)
(5,577 Views)
Hi Boutch19,
I looked into this further and I was in fact incorrect - we do have hardware with independent +/- for each channel:
The NI-9269: https://www.ni.com/en-us/shop/model/ni-9269.html
The NI PXIe-4322: https://www.ni.com/en-us/shop/model/pxie-4322.html
These are both capable of this.  Is this what you are looking for?
Julian R.
(5,562 Views)
Yes
Thanks , I will read the specification
(5,557 Views)
