Difficulty configuring Array microphone using NI-9215 and MAX
Hello All,
             Apologies in advance for the stupid question.
As stated above, I'm having some difficulty configuring a G.R.A.S. Array Microphone Type 40PH though my N1-9215 DAQ. When I attempt to assign a global virtual channel its telling me "no supported devices found" when attempting to configure as a sound pressure sensor.
I can set it up as a voltage analog device, but the readings I get from it are nonsense, its just white noise that doesn't react to sound differences at all.
I fear I have missed something basic!
Apologies if this is on the wrong discussion board.
(3,094 Views)
Accepted by topic author LGardiner
Seems like your mics needs a IEPE input, that your 9215 doesn't support.
Use a DAQ that supports IEPE inputs with a current meeting the requirement of 2mA,
or use a signal conditioner between your mics and the voltage input of your 9215 that provide a IEPE (or CCLD or CCP or ICP or Deltatron.... or  however the company name it ;))
Look in box if you find a conditioner or another DAQ 😄
Greetings from Germany
Henrik
LV since v3.1
(3,059 Views)
