Digital Handshaking with two PCI-DIO-32HS Cards
Hardware: two PCI-DIO-32HS Cards
Software: LabVIEW 5.1, NI DAQ 6.6
Problem:
I'd like to do burst digital handshaking with two PCI-DIO-32HS cards.
One being used for sending bit stream while the other receive.
Suppose I want to use burst handshake mode.
How should I wire the connections?
Where should I wire the REQ, and ACK line from the sending card?
Should I wire REQ from card one to REQ of the other card?
Also, how do I configure labVIEW VI to do burst handshaking mode.
Can anyone send me a VI that can do this.
Thanks a lot.
Message 1 of 1
(3,511 Views)
