Digital I/O
Sir,
I am new to LabView.I am using the DAQ device PCI-6220. In SCB-68 pin connector there is only 8 digital I/O(port 0). But in datasheet of PCI 6220 ,denote that 24 digital I/O.Then How can access the port 1 & port 2?
(3,157 Views)
A SCB-68 has no 'ports'. It's a dumb terminal block with numbered 'pins'. Pin 1 of the 6220 connects to pin 1 of the SCB-68., pin 2 to pin2, etc. Determine which pin is associated with the digital I/O on the 6220 by using the specifications and manual.
(3,154 Views)
