Digital IO Read and Change Event
I am writing an application using Measurement Studio 2005 and DAQmx 8.3 but I am having a bit of a design issue.  I am attempting to use an NI USB-6229 to read the value of a contact switch, and I am interesting in the transition from high to low, low to high, but also the present value of the digital line.  I am using an asynchronous callback function to handle the transition of the digital channel, but this has created a problem with reading the channel value.  Because of the callback, I don't know of a good way to read the current value of the channel without causing a runtime error.  Using an separate tasks to handle the callback and reading the current value doesn't work because the channel is continuous processing the callback function.
Is there a way to read the digital channel without stop the asynchronous callback?  This would seem to be a common problem, but I am not sure of the best way to hand this in measurement studios.  Is there a different solution?
Thanks in advance!
(2,942 Views)
Hello All,
Bryan has posted this question to the Digital I/O forum here. Please refer to that forum for new posts and additional information.
Matt Anderson
Hardware Services Marketing Manager
(2,930 Views)
