Directly wiring AO on SC-2345
I am trying to directly wire an analog output to my gas flow controller to set voltages and change a flow rate. I am using a SC-2345 connector block with a PCI-6229 DAQ. From the pin designations of the SC-2345 I should be connected to AO 0 (Pin 1) and AO GND (Pin 2) in J17. However, using my test panels I can't seem to control the AO 0 using my PCI-6229. Any thoughts?
(2,885 Views)
Accepted by topic author TMorgan
As an update, the issue was one of finding the appropriate AO port on the PCI and matching it with the AO on the board.
(2,869 Views)
