Dispatch multiple digital input to different VIs in different projects
I have a USB-6259 DAQ, and I would like to acquire several digital voltage inputs from different independent VIs.
According to what I read it is not possible to acquire data from multiple digital input channels using mutiple daqmx tasks (even using software timing). As a result I am looking into building a VI which would acquire data from multiple channels using a single task, and into controlling this VI from other VIs using VI server.
Has someone done this before ? Is there a better way to achieve the functionality I need ? Thank you very much for your advice.
(4,401 Views)
Hi astralth,
I haven't tried the setup you've described but I don't see any reason why it wouldn't work. You could also look into shared variables.
https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html
https://www.linkedin.com/in/trentweaver
(4,358 Views)
