Do I need NIDAQ 6.9.3 and also NI-435x Version 1.1 to create a program for a NI435x board?
I am about to install a temp logger program that was written by someone other than me. The target computer already has NIDAQ 6.9.3. Do I also need to install NI-435x Version 1.1 for Windows?
Thanks in advance.
Wil
(2,553 Views)
Greetings,
You will need to install the following drivers to use your NI-435X:
NI-DAQ 6.9.1 (or later)
IVI Engine 1.61 (or later)
VISA 2.5.2 (or later)
After installing these three drivers, you should then install the NI-435X driver.
If you are missing any of these drivers, they can be downloaded from the following location:
http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US
Good luck with your application.
Spencer S.
(2,553 Views)
Thank you Spencer S. I didn't know the IVI engine was required.
After many trials, I finally succeeded with installing the apps. The apps were installed after installing NI-Daq 6.9.3. But when executing the app, it would never exit a loop which would running the Auto Zero vi. I found out later on that the accessories was not selected in NI-Daq. After selecting the proper accessory the app would still continue to fail. Re-installing the app again fixed the problem. Now the app works as advertised. I hope this info is not in vain.
Wil
(2,553 Views)
