Do you have 64-bit drivers for PCI-6023?
My customer is thinking long range. He has a PCI-6023 but want to upgrae to LV2012 Windows7 64-bit. Does the PCI-6023 have a 64-bit driver? However, I think that PCI is obsolete or soon will be. Is there a better soln to the PCI-6023?
(3,578 Views)
It's listed as supported by DAQmx which I would hope you are currently using.
Yes, pc's with pci slots are harder to find. If you are looking for a PCIe or USB solution, perhaps you could explain exactly how the 6023 is currently being used. Have you contacted local Sales Engineer?
(3,559 Views)
Just out of curiousity what else would I being used other than DAQmx? You help is less than helpful, exactly.
(3,544 Views)
Since you asked about the availability of drivers for windows 7, the only conclusion I could come to was that you you were using the older traditional DAQ driver. Since you are apparently using DAQmx, then I dont understand why you would ask if it's available. Sorry for the confusion but you just have to click on the support link at the top of the page to get the latest version and install it.
(3,537 Views)
