Does NI 9236 work on 9162 chassis?
I'm trying to use NI 9236 module on USB-9162 chassis but I cannot detect this module on MAX.
Are they compatible?
I have NI-DAQmx 9.1.
Thank you!
(3,284 Views)
No, the NI 9236 is not supported in the 9162 chassis.
See this table for more information.
(3,281 Views)
gmonjo
You may be interested in trying the cDAQ 9171. It is also a sleeve but it supports the same modules than the 9174/78.
Good luck!
(3,186 Views)
