Multifunction DAQ
Does NI PCI 6259 or NI USB 6211 card give 4-20mA current directly?
Hello
I want to use NI USB 6211 and NI PCI 6259 cards for process control applications.
Do these cards give 4-20 mA current directly or they give only voltage outputs?
What is the best solution to current out put if they are giving only voltage output?
Is there any card that give 4-20mA current output directly?
hari
(3,410 Views)
The 6211 and the 6259 only have voltage output, and don't support current output directly.
The PCI-6704, PCI-6238, PCI-6239, and NI 9265 do support current output directly.
(3,401 Views)
