Does stand alone engine support higher resolution graphics
When using LabView 6.0 and building a stand alone application, the graphics doesn't compaire to the graphics on the developement platform.
(2,636 Views)
It's difficult to tell from here what graphics you are referring to, but if you use the Dialog Controls, then the Operating System you run your application on with automatically place its default controls on the Front Panel. For instance, if you run it on XP, you will get the native XP controls. If you run it on Mac OS X, you see native OS X controls. This may help you out on that. You could give this a try and see how it works.
J.R. Allen
(2,636 Views)
