Does the NI USB-6251 require USB 2.0 port?
I was wondering if anyone can let me know if the USB-6251 requires a USB 2.0 or will run it on a USB 1.0 also.
If so, will running it through a USB 1.0 affect performance? I have not found any related information in the user manuals.
bdb
(3,115 Views)
The USB-6251 can run using USB 1.1, but performance of buffered operations will be decreased.
(3,090 Views)
Thanks for the info.
bdb
(3,074 Views)
This is from notes in the manual:
3
If you are using a USB M Series device in full-speed mode, device performance will be lower and you will not be able to
achieve maximum sampling/update rates.
4
Operating on a full-speed bus may result in lower high-speed full-speed performance.
I doesn't give specifics on how much performance will be lost.  I suspect that depends on your PC and other USB items that are connected.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,057 Views)
