Dont understand Voltage RMS
I have to write some measurement software  that uses a NI-DAQ 6071E. C++ is used as the programming language and the new DAQmx interface is used and looks fine for the moment.
Now I have some Questions about the two functions
DAQmxCreateAIVoltageChan
DAQmxCreateAIVoltageRMSChan
Does the first give me the unmodified sampled values?
Does the second make some calculation on each sample?
I must create the arithmetic mean and the RMS of the samples. Do these functions help me on this. Or must I do the calculations on my own?
I would expect that I have to make the calculations on my own, which is not a problem.
Would be great for some advise
BR
Hans-Juergen Lange
(3,565 Views)
Accepted by topic author Hans-Juergen Lange
Hi Hans-Juergen,
The DAQmxCreateAIVoltageRMSChan() function is only supported for the DMM integrated into the NI ELVIS II and NI ELVIS II+. For the NI 6071E you will have to use DAQmxCreateAIVoltageChan() and perform the calculations on your own.
Brad
Brad Keryan
NI R&D
(3,539 Views)
