Dose PCI-6221 support NI-Traditioanl DAQ?
When I installed the PCI-6221 (M serials) multifunction card by the MAX, I found it only existed in the DAQmx group but nothing in the traditional NI-DAQ group. How can I use the traditional NI-DAQ Api with this card?
(2,857 Views)
I recommend you to use NI-DAQmx because it's much easier to program your board.
You can download Traditional NI-DAQ Compatibility VIs from our website. The Traditional NI-DAQ Compatibility VIs allow you to run LabVIEW applications written in Traditional NI-DAQ on devices that are only supported by NI-DAQmx. There are some functionality restrictions and you must have LV 7.0 or later. Please read the description carefully.
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/9d67f671bcc6850586256e630059308b?OpenDocument
Hope this helps.
Luca
(2,851 Views)
