Driver / Stepper Motor
Can I use USB-6009  to generate the right signal for "Parker / Compumotor M57-51 Motor Drive" to run a M57 Stepper motor?
THANKS!
www.parkermotion.com/manuals/drives/MDrive.pdf
(3,568 Views)
No. The specifications clearly indicate (pages 7 and 13) that 20 mA is required on the so-called TTL inputs. The USB-6009 can only source 8.5 mA.  Also the DO lines on the USB-6009 are software timed, meaning that pulse rates above about 100 Hz will not work and will have significant jitter.
Lynn
(3,544 Views)
Thank you so much Lynn.
(3,540 Views)
