11-27-2006 03:03 PM
11-28-2006
04:04 AM
- last edited on
04-27-2025
01:54 PM
by
Content Cleaner
This card is supposted by both Traditional DAQ and DAQmx device drivers
use the hyperlinks to locate these device drivers
11-28-2006
09:59 AM
- last edited on
04-27-2025
01:54 PM
by
Content Cleaner
Hi David,
He's right about the card being supported under DAQmx or Traditional DAQ - I would recommend using DAQmx if that is an option.
Cheers,
Andrew S.
Message Edited by stilly32 on 11-28-2006 10:00 AM
11-28-2006 11:30 AM
Andrew,
I am using Labview 6.1 and MAX 2.2 under Winows XP
Is This new driver "Traditional DAQ " supports Labview 6.1 and Max 2.2?
Thanks for the help.
David
11-28-2006
05:08 PM
- last edited on
04-27-2025
01:55 PM
by
Content Cleaner
Hi David,
For LabVIEW 6.1, the latest version of the driver that is supported is Tradtional DAQ 7.4 - DAQmx is not supported in LV 6.1.
Hope this helps,
Andrew Stillwell
