Driver for PCI-6071E on linux?
Hi all,
I am on the lookout for a linux driver for the PCI 6071E card.  I couldn't seem to find a comedi version and was wondering whether any one knew of one available or whether I'll have to plunge into the DDK?
Cheers,
Andrew
(3,873 Views)
Hi Andrew,
Depending on which Distro you are using there will be a few options.  I recommend going with DAQmx if possible instead of DAQmx Base since it provides access to more of the hardware's functionality.  You also might want to check out our Linux User's Group for Linux-specific issues (installation etc.).
Best Regards,
John Passiak
(3,854 Views)
Thanks John, I am trying to build an application on Lenny - I'll have a look at those links and try and work out what my best options are.
Cheers,
Andrew
(3,808 Views)
