Drivers PXIe chassis + modules
I've done this years ago but can't get the system running again after reinstalling windows. I have a PCIe-8375 card in my PC and a PXIe-8375 in my PXIe-1071 chassis. Additionally, there is a PXIe-6366 card installed.
Which drivers/software do I need to get the system running? Currently the PC does not boot when connecting the fibre cable so I guess it's a driver problem? Without cable it's fine but I can't access the PXIe hardware obviously.
Benjamin
(1,775 Views)
As a bare minimum for the listed HW, you need the PXI platform services driver and DAQmx driver.
Santhosh
Soliton Technologies
(1,744 Views)
I'm guessing that this is a different PC since it's not booting with the hardware attached. Since it's not booting you'll probably need the BIOS compatibility driver to work around the BIOS issues. You'll also need to set the top DIP switch to "on" on the PCIe card.
https://www.ni.com/en-us/support/downloads/drivers/download.mxi-express-bios-compatibility.html#3311...
Robert
(1,728 Views)
