E-Series DAQCard Not Responding To First IRQ Level on a PCMCIA-PCi adaptor
When I attempt to test the card using MAX I get the "device does not respond to first IRQ-level" error message. I'm using a PCMCIA-PCI card convertor on a EPIA-M1000 motherboard with XP SP1.
(2,767 Views)
DAQ Card is a 6062E PCMCIA type
(2,767 Views)
Hello Graham,
It is possible that the PCMCIA-PCI card converter that you are using will not work with your card. We have tested many of these converters and found that many of them do not work properly with our cards. However, we have found some that do work. Please take a look at the KnowledgeBase link below for additional information. More than likely, you will need to use a different converter.
http://digital.ni.com/public.nsf/websearch/49CC0C97E26A2D5786256B13007C3047?OpenDocument
Bill B
(2,767 Views)
