Easy Way to setup network access to my USB-6501
I can't figure it out.
How do I access my USB-6501 over my network?
Is there something easy to read?  I
(3,563 Views)
What needs to be done on the host computer?
(3,562 Views)
There isn't really a direct way that you can access a USB over a network.  We have several other devices with the same functionality that are specifically designed to be used on a network.  There are ways you can get some functionality using TCP/IP or UDP calls.  Could you elaborate more on what you are trying to do?
Greg H.
(3,540 Views)
Try B&B Electronics   www.bbelec.com. They have E-net to USB adapters.
(3,524 Views)
If you have a specific use-case in mind, you can quicklyy configure a LabVIEW web service [1] to send/receive data from your 6501. Input/output is fairly simple, and there are good examples and documentation [2] for basic operations.
If you want to access your device as if you were using DAQmx over the network, that will take more effort. You could use a web service to write a more general-purpose 'driver', but you may save cost in the long-run if you choose a network device like the NI cDAQ-9191 [3a] with a digital IO module [3b].
[1] Web Services in LabVIEW
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/computer/webservices/webs...
[2] Tutorial: Building and Accessing a LabVIEW Web Service Application (ETS, VxWorks, Windows)
https://www.ni.com/docs/en-US/bundle/labview/page/tutorial-creating-and-publishing-a-labview-web-ser...
[3a] NI cDAQ-9191
https://www.ni.com/en-us/support/model.cdaq-9191.html
[3b] NI 9401
https://www.ni.com/en-us/shop/model/ni-9401.html
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ] [ macOS ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,518 Views)
