Edge counter with hardware reset
Hello all,
I have a PCI-6220 and I would like to configure a counter to count edges with a hardware reset or use my counter to measure linear position without the B input, after words, only with the A input to count edges and the Z input to make the initial position.
Somebody knows how?
Thanks in advance, best regards,
Paulo Carmo
(4,083 Views)
In order to reset the count on a z-index input with your M-series board, you'll need to configure this as an encoder position measurement.  Since you only have an A channel, you won't be able to configure as a quadrature encoder.  What you
*can* do is configure as a "Two Pulse Encoder"  which counts up for each edge at the channel A input and counts down
for each edge at the channel B input.  Just wire one of those inputs direct to DGND to eliminate any possibility of edges.
You'll further need to configure and enable the z-index reload feature for encoders.  Here's the tricky part - you are required
to define the A,B state in which a high state of Z will reload the z-index value.  The problem is that the z-index signal may
not have the timing characteristics you'd like.   I don't know if your app is particularly sensitive to this issue, but I'll lay it
out:
Let's suppose you set z-index reload phase to be A-Low, B-Low with one of them hardwired to DGND (guaranteed Low).
Here are 3 things that could happen:
1. A is low throughout the Z-index signal's high time.  Your reload works just as you want.  (It will probably also work as
you want for other situations where A is low during exactly one segment of the Z-index signal's high time.  A could be
high during 0,1,or 2 distinct segments of that time.  The key thing is that once A is low, it can't transition to high and back
to low in order to work as you probably want.)
2. A is high throughout the Z-index signal's high time.  No reload takes place due to the wrong A,B phase.
3. A has 2 or more distinct segments of low time during the Z-index signal's high time.  2 or more reloads will take place,
causing the intervening edge counts to be ignored.
-Kevin P
(4,078 Views)
Some years back I had a flow sensor with pulse output but only a (fieldpoint) encoder input left to read out.  I created my B channel with a RC delay and divided my reading by 4 . Done 🙂
Critical point is the max pulse rate you expect. (I think I was fine with a 470R from A to B and 100nF from B to GND, all connected at  the screw termial )
Greetings from Germany
Henrik
LV since v3.1
(4,067 Views)
Thought I would contribute a 3rd approach:
Pro:
-Does not depend on phase of z index
-No external components required
Con:
-May only sample the count register based off of software-timing (although the reset is done in hardware)
-EDIT: Will not work on M Series or TIO (Counter/Timer) boards.  Verified on X and E series.  Would possibly work with 621x bus-powered M Series but I am not certain without trying it.
Best Regards,
John Passiak
(4,055 Views)
I like John P's period measurement method better than my earlier suggestion -- insensitivity to A(,B) state is a *big* plus.  I reread your initial post and there's no mention of needing a hardware-timed buffer of count measurements, so I think you're in good shape.   Just one other thing I'd note -- count reset during period measurement *only* resets to 0, but odds are pretty high that's exactly what you want to reset to.
John -- I'm surprised by your comment that this won't work on M-series or TIO series but *will* work on E-series.  I don't have hw at hand to test it, but I don't see where the problem would be.  What am I missing?
-Kevin P
(4,029 Views)
Hi Kevin,
I was surprised too to be honest...
I filed this as a bug (CAR 284722) for R&D to take a look.  I'm not sure if it's a hardware pecuiliarity or if it's fixable in software though.
Best Regards,
John Passiak
(4,025 Views)
