 Danfu
			Danfu
			02-26-2008 04:33 PM
02-27-2008 05:41 PM
Danfu,
The anti-aliasing filter on our DAQ cards is applied before the signal reaches the ADC. So any frequency content that is higher than the two presets on the 6115 (50kHz or 500kHz) will be attenuated.
You can access this property in CVI by using the AI_Change_Parameter function to set the filter value. You can find this information in the 6115/6120 User Manual on page 101.
