Engine DAQ
Hello, So I've connected a Crank angle encoder and an in-cylinder pressure sensor to my NI 6008 USB DAQ. The signal from the encoder is digital and the signal from the pressure sensor is analog. I was wondering how to I get my DAQ to measure the pressure at the corresponding crank angles? Will Signal Express be able to do it? Thank you.
Message 1 of 1
(2,816 Views)
