Equivalent function for DIG_Prt_Config in NIDAQmx.
Hi stf13,
I don't know the answer, but here are some things to look into:
  • Data layout in the array: DAQmxReadDigitalLines unpacks the data into a separate uInt8 for each line. If this is not what you are expecting, DAQmxReadDigitalU8 might be what you need.
  • Pinout: double check that the physical channel name corresponds to the lines you have connected. Port3 corresponds to APC in the pinout diagrams from the PCI-DIO-96 manual.
  • Errors: does DAQmxReadDigitalLines return an error or warning? A timeout error could indicate a connection problem with the handshaking lines.
  • Return values: what do 'read' and 'bytesPerSamp' get set to after the read?
  • Timing: does your program call start & read before the change actually occurs?
Brad
Brad Keryan
NI R&D
Message 11 of 11
(728 Views)
